SW07 API book
SW07 API book
There's an API book on amazon for SW2006. I know quite a bit changed in the API from '06 to '07. Does anyone think it still may be worth while to get or does anyone know if/when an '07 API book will be available.
RE: SW07 API book
SA
RE: SW07 API book
"If you developed your application using Visual Basic 6.0 on Windows XP, then the controls on your forms and dialogs might behave unexpectedly. Therefore, it is recommended that you port your application to Microsoft Visual Basic .NET or peruse Microsoft's Knowledge Base and the internet for possible workarounds."
But I've also heard that SW2007 isn't quite ready for .NET and at least at this time VB6 is the most stable and consistant.
Here's my situation. I have a HUGE macro that does a whole bunch of stuff - basic PDM functions/file management, Excel data tracking, and some CAD manipulation. I'm working on converting it into a stand-alone application, but before I get started I want to make sure I'm using the correct platform. I'm open to input.
RE: SW07 API book
SA
