INSTANCE ID
INSTANCE ID
INSTANCE ID
Is there anyway to change the instance ID of a component in solidworks?
Matthew
RE: INSTANCE ID
I have not asked the question since SW2001+, but the answer from SW back then was no.
SA
RE: INSTANCE ID
As far as I know, that information is hard-coded into the document and is not accessible.
cheers
RE: INSTANCE ID
Out of curiosity, why do you want to change it?
Eric
RE: INSTANCE ID
If you want to change the order of components in your BOM... that's controlled by the order of the components in your assembly "tree"... if your BOM is set to FOLLOW ASSEMBLY ORDER.
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
FAQ376
