Base Plate for Cantilevered PIPE Column
I've seen threads for cantilevered columns, but all information I have come across such as AISC Design Guide 1 seems to be specific to wide flange columns. Also, I have found an article for pipe column base plates, but it was for gravity loading. Is there any sort of guide to design a base plate for a round hollow section that is subjected to moments?
RE: Base Plate for Cantilevered PIPE Column
Take a look at this design manual, it seems very comprehensive to me.
htt
-Mike
I couldn't find anything in a general search, but after wading through 33 pages of this forum, I found a similar question. I don't know how I missed it, but there is a small section in the AISC Design Guide that references how to treat tube and pipe. I will definitely check out the RISA reference. Thanks again.
