help for variable mastery
I have a problem:
I work on batch mode on ADAMS/VIEW
I need to find a adams's function which could do that:
I enter a paramter "i". It's a integer. It is define between 1 and 40. I need an integer or a string in output like that:
               i   |  output
               1   |    01
               2   |    02
               3   |    03
               9   |    09
               10  |    10
               11  |    11
               39  |    39
               40  |    40
RE: help for variable mastery
If youa re familar with the SPRINF function in c, thsi si trivial,
Create your design variable
var cre var=DV_2 int=3
then use it as
STR_SPRINTF( "%02d" , {DV_2} )
This will return the string as you want it.
Jesper Slattengren
www.prattmiller.com
