rotate drawings views
i copy this directly from the solid works helpo menu yet when i attempt to trying the menus are not there. has anyone else experienced this.
To align a drawing view to a model edge:
Select a linear model edge in a drawing view.
Click Tools, Align Drawing View, Horizontal Edge or Vertical Edge.
The view rotates until the selected edge is oriented horizontally or vertically.
If any views are projected from a view that you rotate this way, the projected views update to maintain their projection.
For additional methods of rotating views, see Rotating Views.
RE: rotate drawings views
RMB click in a toolbar and select Customize > Options
Then select both Show All buttons.
This forces all menus to show all available selections.
