finding torque?
finding torque?
finding torque?
I decided the its size and materails.
How can i decide appropriate torque for nut?
RE: finding torque?
Hi bredford:
the answer to your question is not that simple. Without knowing more detail of the connection, an answer is not possible. What is the loading of the joint ? Is it tension or shear or both ? Is it fatigue critical ? You find simple equations in text books but the detail analysis of preload in bolted connection is more complex. Many papers have been written all over the world on the subject."How much preload is enough ?" is one of the many questions. Because that will finally effect the run-on torque. The two simple euqations for a preliminary estimate found are:
 For dry bolts                  Torque = ( Ppreload * 2 rb ) / 5
 For lubed bolts               Torque = ( Ppreload * 2 rb ) / 6.7
 2rb is the shank diameter of the bolt !
greetings FGH
RE: finding torque?
another calculator - if you email them the specific information ( material property, etc) they will even add it for you!
http://www.futek.com/boltcalc.asp
Keep the wheels Down.......
