help with loop command using *IF *ELSE, *ENDIF, *DO on ansys linux os
Hi
i am using ansys multiphysics v10 on a red hat linux enterprise 4  os  64 bit machine.
I  was wondering if anyone out there had a simple example or input listing of a loop command using *IF *ELSE, *ENDIF,  *DO
i was trying out something myself using these commands and everything works fine when using ansys on windows but when i run the same in ansys on linux it screws up.
i am confused and i am wondering if its something to do with the syntax when using linux os.
can anyone help
