Custom Property Display
Hi All,
I'm having an issue with a custom property of mine. I want to display the sum of two dimensions in a note on the drawing for a part.
I created an equation defining a value of "length" which equals the sum of the dimensions. Then I created a custom property equal to that value "length".
The value shows at 26.25 in the property manager but when I insert the property into my note it displays as -2. What's the deal. The property is defined as a text item.
RE: Custom Property Display
overkill04,
From your description, I duplicated what you did.  The value in my note equaled what was displayed in the property managaer.  Where are you creating the note?  I did mine in a drawing.  In what tab did you create the custom property in the model (custom or configuration specific)?  If you put the note into a drawing, what options did you pick (Current document, Model in view to which annotaion is attached, etc.)?
SA
I'll try it a few other ways to see if there's something not quite adding up.
But to answer your question, I created the note in a drawing for the part. I created the custom property in the Part file, and it was NOT configuration specific.
And I used the model view option to insert the property.
Do you have a length custom property in the configuration specific tab that is set to -2?  SolidWorks takes the value in the configuration specific tab before taking the value in the custom tab.
Do you have more than one config of the part?
Are you using a DT?
Which version of SW?
cheers
