symbols display as letters - release 10
for any .idw that i open up or create, the annotation symbols, ie diameter and feature control frame symbols show up as regular alphabetic letters. For instance, diameter shows up as "n". All the guys in the shop are constanly asking me what "n" is supposed to mean on the print. The font for the test style is Arial in all the drawings. Any idea what is going on here?
RE: symbols display as letters - release 10
David
Arial is my prefered font for text on drawings, then if you use the symbol tool in the text editor it will autmatially switch to AIGDT for the symbol. If you need to edit a dimension because the symbols are missing highlight the letters that should be symbols and change your font to AIGDT.
David
David
David
