Variable pressure in Workbench
Does anyone know how to put a variable pressure in Workbench. There's a drop down menu to select other options but there's only one option and that's constant.
RE: Variable pressure in Workbench
Baldy,
You're going to have to use the insert commands function under the Solution tab.  Basic procedure goes like such:
-Define local coordinate system
-Get/define all necessary parameters/arrays
-Define pressure function (SFFUN command)
Have you done this before in Ansys?  If not I could try to provide you with a macro which may help you.
-Brian
I have never used Commands in ANSYS Classic.
But while reading the Help Documentation, it states that you need a License Level of ANSYS Professional and above to be able to use the Commands. Which I don't have, so thanks anyways.
Hi
I think Ansys 11 will have an function(or table) to give to your pressure, so have patience.
Ansys 11 will come out at the end of feb.
Grtz
Garry
it may be simpler than this, without waiting for future versions (do the best you can with what you have, no? winky smile )
let's say you have a pressure varying with the coordinate Z of the system CSYS,21 (whatever this coord sys can be).
If you don't want to cope with SFFUN, simply discretize your P-variation law in, say, 10 P values at 10 Z coords.
Then, add a Commands snippet in the Solution and add these commands:
/PREP7
*DIM,P_TABLE,table,10,,,Z,,,21
P_TABLE(1)=p1,p2,...,p10 !pressure values
P_TABLE(1,0)=z1,z2,...,z10 !coord values
cmsel,s,COMPONENT_OF_PRESSURIZED_SURFS
SF,all,pres,%P_TABLE%
allsel
/SOLU
et voilĂ ! The SFFUN method is, by far, more sophisticated, but also more difficult to catch up...
Hope this can help.
