Multiple Instances of Solidworks
Prior to SW2007, I was able to run 2+ instances of SW at a time. With dual monitors, it was handy for me to reference a drawing on one screen while working on a new drawing on the other screen. I preferred doing this over printing out the drawing I was referencing.
Prior to SW2007, I just got a warning along the lines of: "A journal file could not be created. Another instance of solidworks may be running on this machine." I would click "OK" and a second instance of solidworks would open and function normally.
With SW2007 installed (sp2.0), one of the following things happen:
1)Nothing
2)I will get the same warning detailed above, click ok, a new solidworks window will come up briefly and either lock up or close by itself.
Any suggestions on resolving this would be greatly appreciated.
JEM
Solidworks 2007 SP2.0
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo
XP Pro SP2.0
1)Nothing
JEM
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo
XP Pro SP2.0
RE: Multiple Instances of Solidworks
I'm not sure why you have the problem, that same scenario works on my machine. Running Windows XP Pro and SW2007 SP2.2. I got the typical error about a journal file, now it added that Autorecover won't work and then SW started and worked just fine. I know I have also had 2007 and 2006 running at the same time.
mncad
We are set up on a network license. I watched my windows task manager when I try to start my second instance of solidworks. It temporarily flashes a second instance of SLDWORKS.exe and a second instance of SolidWorksLicTemp.0001. Then these lines just plain go away.
The only weird thing is that I had run multiple instances before with the network license set up the same way.
Is it possible that this could be causing me problems? If so, how can I "trick" my license setup?
JEM
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo XP Pro SP2.0
Anyway, I disabled the switch that ran that macro at Solidworks startup and my problem went away. I simply assigned a shortcut key to run the macro when need be.
Thanks for the suggestions. Sorry to waste y'alls time.
JEM
2GB Ram/3GB Switch
Quadro FX1300
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
FAQ376
Matt
Silicon Valley, CA
