Excel Charts / VBA
Excel Charts / VBA
Excel Charts / VBA
I want to plot data on an Excel chart using VBA.  In Quickbasic there is a "Line" statement that can be used, e.g., Line (10,10)-(20,20).  Is there anything similar to this in VBA?
RE: Excel Charts / VBA
Do you want to manipulate a Chart (i.e. a graph plotting data from the worksheet), or draw Shapes?
First option you use the ChartObjects collection of the worksheet, second option you use the Shapes collection.
Cheers,
Joerd
joerd,
If I use ChartObjects with AddLine it says "object does not support this property or method".  I am trying to draw lines on a chart using coordinates generated in the Basic program and not in cells.
You need a little more. The ChartObject has a Shapes collection, like the worksheet:
CODE
Dim c As ChartObject, L As Shape
Set c = ActiveSheet.ChartObjects(1)
Set L = c.Chart.Shapes.AddLine(88., 211., 267., 246.)
Cheers,
Joerd
