Need comments on Aero-tech books?
Hi All, I have Bruhn, Roark, Peery, Hoerner etc but still need guidance and references for some hand calc structural issues from time-to-time. From variuos forums on Eng-tips I see suggestions for Niu, Flabel and Megson for structures to add to my library. I'd like your astute comments for my dilemma. Basically hand-calc methods since I do not have NASTRAN, Ansys etc available. BTW I usually get good service and prices thru Alibris bookseller. Thanks JQC
RE: Need comments on Aero-tech books?
http://trs.nis.nasa.gov/archive/00000254/
the price is right!
Thank you for the wonderful reference link!!
But it would be a LOT easier to start learning with a book like Flabel's, and only then move to Bruhn's or Niu's more in-depth treatments of some topics. But my college prof didn't agree...
Steven Fahey, CET
More good references:
Stress Analysis Manual AFFDL-TR-69-42
Air Force Flight Dynamics Laboratory, Air Force Systems Command, Wright-Patterson Air Force Base
Gene E. Maddux
National Technical Information Service, Springfield, VA 22161
_________________________
NACA Reports
Search
http://naca.larc.nasa.gov/?method=simple
Diagonal Tension
NACA TN-2661 A Summary of Diagonal Tension Part I : Methods of Analysis
ht
NACA TN-2662 Handbook of Structural Stability Part II - Experimental Evidence
ht
Buckling
NACA TN-902 Description of Stress-Strain Curves of Three Parameters
ht
NACA TN-3781 Handbook of Structural Stability Part I - Buckling of Flat Plates
htt
NACA TN-3782 Handbook of Structural Stability Part II - Buckling of Composite Elements
htt
NACA TN-3783 Handbook of Structural Stability Part III - Buckling of Curved Plates and Shells
ht
NACA TN-3784 Handbook of Structural Stability PartI IV - Failure of Plates and Composite Elements
htt
NACA TN-3785 Handbook of Structural Stability Part V – Comp. Strength of Flat Stiffened Panels
htt
NACA TN 3786 Handbook of Structural Stability Part VI -Strength of Stiffened Curved Plates and Shells
htt
Product Engineering
Analysis of Lugs and Shear Pins Made of Aluminum and Steel Alloys
F. P. Cozzone, M. A. Melcon and F. M. Hoblit
Product Engineering, Volume 21, Number 5, pages 113-117, May 1950
Developments in the Analysis of Lugs and Shear Pins
Product Engineering, Volume 24, Number 6, pages 160-170, June 1953
Also check out:
Abercrombie Baphoofnik's Listmania Lists ...
on Amazon.com for Aircraft Stress Analysis, Piping Stress Analysis, Composites, Finite Element Analysis, Visual Basic for Applications, Excel Spreadsheets, Linux, Mathematics, Subchapter S Corporation, Newspapers and Magazines, World Travel, Chocolate, Good Gear, Good "Stuff", Guns and Butter, Philosophy, Liberty, Capitalism, Economics ...
htt
Best of luck!
good list; unfortunately many of the links are broken
for instance
A summary of diagonal tension Part I : methods of analysis
is now here:
http:
and part II
A summary of diagonal tension Part II : experimental evidence
is now here:
http:
the NACA reports search site
is just gone, don't know where. Though many appear to be still free here
http://ntrs.nasa.gov/search.jsp
The correct address for the Ramberg-Osgood paper is
htt
sorry for the inconvenience
prost,
My apologies.
You got the gist of it ...
Best of luck.
One more time,
Gene E. Maddux
NACA Reports
Search
http://ntrs.nasa.gov/search.jsp?N=17&Ne=2
Diagonal Tension
http://nt
Paul Kuhn, James P. Peterson, L. Ross Levin
http://n
Buckling
http
Ramberg & Osgood
http://n
George Gerard and Herbert Becker
http://
http://n
http://n
George Gerard
http://n
George Gerard
http://n
Herbert Becker
Product Engineering
A short list of good books ...
Engineering
Analysis and Design of Flight Vehicle Structures Elmer F. Bruhn
Aircraft Structures, First Edition David J. Peery
Stresses in Aircraft and Shell Structures Paul Kuhn
Advanced Mechanics of Materials Fred Seely and James Smith
Airplane Structures A.S. Niles and J.S. Newell
Theory of Plates Stephen Timoshenko
Theory of Elastic Stability Stephen Timoshenko
A Supplement to Analysis and Design of Flight Vehicle Structures William F. McCombs
Engineering Column Analysis – The Analysis of Compression Members William F. McCombs
Weight-Strength Analysis of Aircraft Structures Francis R. Shanley
Strength of Materials Francis R. Shanley
Mechanics of Materials Francis R. Shanley
Mechanics of Materials Gere and Timoshenko
Advanced Mechanics of Materials Stephen Timoshenko
Advanced Mechanics of Materials A.P. Boresi, R.J. Schmidt
Fundamentals of Aircraft Design Leland Nicolai
Helicopter Performance, Stability, and Control Raymond W. Prouty
Aerodynamics of the Helicopter Alfred Gessow, Garry Myers Jr.
MSC/NASTRAN Primer, Static and Normal Modes Analysis H.G. Schaeffer
Introduction to Flight John D. Anderson, Jr.
Fundamentals of Aerodynamics John D. Anderson, Jr.
Computational Fluid Dynamics John D. Anderson, Jr.
Excel 2003 Power Programming with VBA John Walkenbach
Excel 2003 Formulas John Walkenbach
UNIX in a Nutshell Arnold Robbins
The VNR Concise Encyclopedia of Mathematics Gellert/Kustner/Hellwich/Kastner
Composite Materials
Mechanics of Composite Materials Robert M. Jones
Mechanics of Composite Structures László P. Kollár
Design and Manufacture of Composite Structures Geoff Eckold
Primer on Composite Materials Analysis John C. Halpin
Principles of Composite Material Mechanics Ronald F. Gibson
Mechanics of Composite Materials Autar K. Kaw
Composite Airframe Structures Michael C. Y. Niu
Honeycomb Sandwich Design Technology Hexcel Composites
See TSB124 and TSB120.
h
Honeycomb Sandwich Design Technology references:
Honeycomb Technology: Materials, Design, Manufacturing, Applications and Testing by Tom Bitzer
An Introduction to Sandwich Construction by D. Zenkert
Introduction to Pipe Stress Analysis Sockalingam (Sam) Kannappan
Piping Stress Handbook Victor Helguero
Piping and Pipe Support Systems P.R. Smith and T.J. Van Laan
Practical Guide to ASME B31.3: Process Piping Glynn Woods & Roy Baguley
Flow of Fluids Through Valves, Fittings and Pipe Crane Technical Paper 410
Design of Piping Systems M. W. Kellogg Company
Piping Design and Engineering Bluebook Anvil International
(formerly Piping Design and Engineering by Grinnell, Inc)
Best of luck.
The Astronautics Structures Manual can currently be found at:
As long as you're listing all the NACA Handbook of Structural Stability books, add in Part VII:
Strength of Thin-wing Construction
NASA TN D-162
http:
Author(s): Gerard, George; Becker, Herbert
