How do you align the dimensions in SE Draft?
I would like to use a feature like Pro/e snap lines to make all my dims line up on the drawing.  Is this a possible feature or do I just have to eyeball it?
RE: How do you align the dimensions in SE Draft?
there is a function for that:
Tools --> Dimensions --> Line Up Text
there are verious options for an anlignment. Select
the first one to which you would them align to and
then select the others.
You may also insert a button into one of the toolbars when
not already there: RMB into the empty space of one of the
toolbars --> Cutomize --> Toolbars --> Dimensions. Hoover
over the icons and then just drag the one to the toolbar.
dy
dy
thank you, it works but it lines up the text and not the lines.  This is a problem for dimensions that have an offset leader, but it is ok.  again thanks.
What if I wanted to make the dimensions spaced equally, like a half inch between each one as they are stacked?
Global change:
go to Format --> Style --> Stile Type Dimension and select Style
you want. Then 'Modify' --> Tab 'Lines and Coordinate' change
the value for 'Stack Pitch' default is 3 times the current font
size.
For a local change select one of the stacked dimensions, RMB
Properties --> Tab 'Lines and Coordinate' and change the value
as above apply with OK
dy
You could also us the grid display on the draft sheet as a guide.
Hey dy, be careful "hoovering" over icons - they could all get sucked up and lost !! smile
bc
BC,
aah, now I know why I have to clean so often my mouse which
is full of debris, there they are deposited .. winky smile
dy
