team working without team center - Possible??
Hi, I´m working whit NX4 and I would like to know if it´s possible for two person to work at the same time in the same project: I mean each in differents sub assembly but both saving work in the same hard drive.
I know that team center is probably the best way to do it but I would prefer a shiper way .
Thanks a lot
RE: team working without team center - Possible??
Yes it is possible. You will need to coordinate the updating of the higher level assemblies where your 'independent' sub-assemblies get joined.
Ben Loosli
Sr IS Technologist
L-3 Communications
So long as you make sure that two people aren't trying to modify the same parts at the same time, it's fine. We work like this from time to time. So long as you communicate well with each other as to who's doing what, there's no problem.
