STEP importation problem
Trying to import data from a STEP file (~120 MB) created with CATIA v5r16 by another company I repeatedly fail to import correctly all the data, receiving the following error:
"Low memory status, file is partially transferred. Increase memory. Element not created"
The machine I'm working on has 2 GB of RAM, I've checked and the maximum usage peaked at around 1.4 Gb... any hints/ideas as to how to resolve this problem? Currently it's running v5r12.
RE: STEP importation problem
Data processing works fine untill memory usage reaches around 1.4 GB, after that I receive the error message as shown above and all the parts processed afterwards are not created. As some of them are the ones I actally need, it's quite frustrating. Aside from asking to be sent for just the parts I need, is there any way I can choose what parts to create before actually starting to import the STEP file and thus saving the memory 'wasted' by the parts I don't need to import?
This will break the step file into assembly mode provided it was created as such.
Derek
Regarding the move XP and R16, unfortunately I can (and will) only suggest it, not enforce it.
