Contact surface or node contact
I'm using ABAQUS/Explicit and i'd like to modelize contact between a tool and a sheet. I use a master/slave contact algorithm with penalty methods. To define the slave surface i can choose Node or Surface. I get results which are very differents from one to the others. What should i choose? Where did the difference come from? I think from interpolation...
Pitch
Pitch
