Will a rail job help me get a structural job later?
Hi everyone,
I'm a civil grad with no experience. Eventually I'd like to go into structural but I've been looking for 2 months with no luck. I recently received an offer for a transportation position doing alignment, drainage and other rail stuff. Right now I have no other offer and I don't know if I should take this job. Would this job help me in getting a structural position later? The two are unrelated so I don't think it'd make much difference, except I'd have some work experience... If it doesn't help me with getting a structural position, should I take it? I'm afraid that I'd be setting my career direction into transportation and I wouldn't be able to go into structural later. Any opinion on this? Please help! Thanks!
RE: Will a rail job help me get a structural job later?
Does the job sound interesting to you? Is it an engineering (as opposed to drafting) job - will you be able to count it as expereince towards your PE?
If the answer to all those is yes I suggest that a bird in the hand is worth two in the bush. Moving sideways into your preferred area of interest is much easier than finding the perfect job when unemployed.
Cheers
Greg Locock
tokki.. if you want to do design work eventually.. either go back to school (structural emphasis) or just find a drafter position at a structural engineering firm. It wont pay like engineers but at least you will be able to find design job later (either at the same company or somewhere else).
If you do it other way then you will get a pay cut later.
Find out from the firm that gave you an offer whether they have a structural discipline inhouse.  Many firms doing transportation work have inhouse structurals doing transportation related facilities such as maintenance buildings or stations/bridges.
Pure structural design firms and A/E with inhouse structurals alike have entry level engineers with civil background.  That's how most structural engineers start out.
