Bolted flange verifications
Having a bolted flange for heavy applications subjected to bending due to an external load i determined the loaction of the neutral axis through the Reinforced concrete structure theory. This method DOES NOT allow to consider the bolt preload. The life prediction of the bolts is anyway pretty close to experimental results. Does anyone have suggestions on other method i could use to determine the stress distribution on the flange in order to accomplish a better confidence in my results?
any help is appreciated
RE: Bolted flange verifications
Design of Welded Structures by Omar W. Blodgett
Manual of Steel Construction by A.I.S.C 9th Edition
Hope this helps.
May be you can use this site: http://www.extra.hu/irwin/ervin2.html
Here in the references you can see an example in ppt format and in doc format too.
Irwin
