Punching Shear Resistance
I would like to work out the thickness of concrete that I require. My punching shear is 5.915 kN/m2 and I am using 60 MPa compressive strength concrete.
RE: Punching Shear Resistance
What are you dealing with... spread footing, flat plate, flat slab...design code...design methodology?
Flat plate, not to sure on the design code, I have base plates 350mmx350mm dynabolted to the concrete floor.
