Export X,Y,Z Co-ordinates
I have a 3D sketch that I used to make a sweep of tubing that I need bent. Problem is that the tube bender uses autocad and will need the 3D data to make the bends. Good thing is that none of the sketches are splines, so I'm hoping that it won't be to hard to reproduce.
Problem is though how do I export the data into a table? I've found a macro that does it in 2D not 3D, but I also need to have the start point labelled 0,0,0.
Any ideas?
Any ideas?
RE: Export X,Y,Z Co-ordinates
Cheers
Greg Locock
http://w
http
