Logarithmic scale in Autocad.
I am looking for another way to see if AutoCad environment can display values in base 10 logarithmic scales to use with Logarithmic graphs. I wrote small AutoLisp program that actually works but that was in 1994.
Does anyone know if there is another way?
RE: Logarithmic scale in Autocad.
If your data is in an Excel worksheet, you can insert the data and any charts into AutoCAD using OLE.
Don Phillips
http://worthingtonengineering.com
