resources for solar / battery pairings
Hi all.
I am looking for any kind of advice or online resources regarding using solar cells to charge batteries.
I am working on a project with low-powered components that will run off of a rechargeable battery that I'd like to charge up during the day and be able to run the components during the night.
I am having trouble figuring out what voltage, amperage, etc. is needed to charge the batteries in a full day of sun.  The components will probably need to run off 5 volts, at about 0.5amps.
Thanks for any advice.  I'm a bit new to this stuff.
Cheers,
     DHD
RE: resources for solar / battery pairings
Figure about 3 hours of sun a day.  Whatever current the panel states, you will never get more than 66% of that.  Solar panels are current devices.  A 12V panel can be connected to a 6V battery.  If solar panel current is more than 5% of AH of battery, an charge controller is needed.  Battery should be rated to power the device for at least 5 days without sun.
