non-default part confiuration in assembly
how do you show/insert a configuration of a part other than its default state? I have a model of a motor and gearbox as one part. I made an alternate configuration to show the gearbox mounted in the opposite direction. When i insert the part into the machine assembly, i don't see where i can select which configuration i want to use.
RE: non-default part confiuration in assembly
Cole M
CSWP, CSWST, CSWI, CPDM
SW06
SW07
IBM T42p, 2g proc., 1g RAM,ATI Mobility Fire GL T2
HP XW4100, 3g proc., 3g RAM, Nvidia Quadro 980 XGL
HP XW4300, 3.4g proc, 2.5g RAM, ATI Fire GL 3100
I have made an assy drawing and inserted a BOM.
Can anyone suggest why the configuration name is appearing in the part number column? (i.e. "default" is not a very useful part number)
Cheers, Nick
The configurations were indeed generated by a design table. Is there a way to get the BOM to reference the Document Name?
Cheers
Perhaps one of the API gurus know of a macro which would do this for you.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.1 on WinXP SP2
SolidWorks 2007 SP2.1 on WinXP SP2
Yes ... the property is $PARTNUMBER with the variable being $D for Document Name and $C for Configuration Name.
Has that always been available? (please say no ... I'd be embarrassed to admit to how many I've changed manually)
needless to say that $D is very useful... Cheers.
