Can't Draw in 3D using autocad 2007
I just (friday) updated to AutoCad Mechanical 2007. I was trying to draw a helix and then rotate it into the proper position, but it would only let me rotate on the XY plane and not in any 3D motions. What I tried: going to a different view (front vs. top) and rotating. I also tried to just draw a solid while in front view and even when i clicked away from the XY plane it still selected a point on it. I'm baffled. please help.
RE: Can't Draw in 3D using autocad 2007
"Everybody is ignorant, only on different subjects." — Will Rogers
Zuccus
then either use constrained orbit or free orbit.
hope this helps,
-Vic
