Supplier for plate springs ( photo inside)
RE: Supplier for plate springs ( photo inside)
In this case the material is elgiloy but can be inconel stainless steel or metals for cryogenic aplications.
If I understand your description and the photo properly, this is a garter spring made with rectangular wire/strip instead of round wire.  Associated Spring can make just about any type of spring, and they are extremely competent in technically challenging designs, materials, etc.
btw, maybe you should find a different pic-posting site ... i don't like getting redirected to on-line casinos ...
Thanks TVP
I will ask
rb1957 sorry,
any other ?
These are usually custom designed springs for lip seals such as made by Balseal or Omniseal, etc. If you need exactly the same spring then the best is to find the seal manufacturer and purchase the spring. If you need similar spring then there are many other springs that will do the same work. For example Balseal patented slanted coils spring and others.
