Press fit Analysis of delrin with through rod.
I am trying to do some hand calculations/analysis on a 3 part assembly.
The assembly has a Thin walled steel tube with a delrin bushing press fit inside. There is then a steel rod which is placed through the bushing and the ID of the delrin is the contacting surface for rotation. Rod is fixed and the delrin rotates around it.
What I am trying to determine is the Pressure on the Delring bushing(and how much it compresses), the amount of preload and the force of friction betwen the delrin bushing ID and the steel rod.
I found a calculator(c5.13) which does some of the analysis for you.
http://www.tribology-abc.com/
However, I was wondering if anyone knew the calculations that were behind it. I thought they were called Lame's equations but I can't find much info.
Any help would be appreciated.
RE: Press fit Analysis of delrin with through rod.
Yes, Lame's equations - Hoop stress and radial pressure distribution.
Sigma-R = A + B/d^2
Sigma-T = A - B/d^2
http://www-training.llnl.gov/training/hc/5060/Design.html
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
