HEAT TREAT DIST. AND STOCK SIZE
I would love some confirmation if I am on right track or way off here. We make a landing gear axle out of 4340 steel that always moves a bit at heat treat-we roll quench after heating to 1500 for 2 hrs.70% of length is solid 2" diameter, ends are tapered and hollowed out, min wall thickness approx 3/16"
So - this time around there is more movement than normal, coinciding with a raw material change from 2 1/2 diameter CF round bar to 2 1/2 diameter cores that had been removed from 7" diameter round bar.
Could this be a contributing factor? we do a harden and temper before turning for machinability, but it may not be taking all the movement out.
thanks
thanks
RE: HEAT TREAT DIST. AND STOCK SIZE
http://www.welding-advisers.com/
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
