Oxygen production power usage
I am not sure if this is the correct forum for this however if you know of a better forum let me know.
I am interested to know the power consumption of oxygen gas plant for a hospital. I understand that this is something that may very depending on the system, therefore if you could specify the type of plant and the power consumption per kg of oxygen (kW/kg).
Thank you in advance.
