Vibration monitoring of screw compressor
We have an propylene refrigerant oil flooded twin screw compressor. The only vibration monitoring of the compressor is the thrust probes and the casing vibration.
Thre are sleeve bearings in the compressor, anyone has carry out installation and monitoring of radial vibration on the sleeve bearings of such type of compressor.
