dimensional Tolerance
I am in the process of reverse engineering a part. i have measured key areas of 4 each of the same part... i have come up with the standard deviation, and the mean of these dims...
how would i go about determining the manufacturing tolerance of each dim???i is it just the mean, the STNDDIV or some other method??
thanks,
southpaw...
thanks,
southpaw...
RE: dimensional Tolerance
If a process is stable and normally distributed then the ratio of the tolerance range to the 6 sigma range is called Cp. If this is greater than 1 then you have a tolerably good process, 1.33 is preferred and 1.67 is what we currently aim for.
So a starting point for your dimension would be
mean +/- 3*stddev
But that really is a lousy way to do it! (tolerances should be the result of a tolerance study, not a function of the process that makes the part)
Cheers
Greg Locock
