Single Assembly JT File
Hi All,
Does anyone know how to export a single assembly JT file from NX4? Default exports a JT file of the Top level assembly and then creates a sub folder on the OS with a JT file of each instance.
What options do you need to define within Preferences > JT to create the single file?
Thanks in advance.
RE: Single Assembly JT File
4.0.3.3
From Preferences->JT, choose the File tab and then select Organize JT Files->As a Single File.
Not tried it, but would assume this does what you're asking for.
Paul Phillips
Specialty Engineered Automation
http://www.sea4ug.com
