MTO - material take off (or) make to order
Dear Folks,
Could any one explain the terminalogy MTO?
is it material take off or is it make to order?
This one i found it in our project deliverables. since i am new to this field, if some one can help me what is material take off, is great help.
Thomos
RE: MTO - material take off (or) make to order
I think it's going to depend on the context, like most abbreviations.  Material Takeoff is pretty common.  I'm sure there are others.
Thomos - If you are asking what is a Material Take Off - it is the process of going through the design drawings, sketches, applicable codes and specifications to determine the quantity of meterials required for a particular project.  An MTO should result in a Bill of Material (BOM) or a listing of everything that needs to be purchased or supplied.
