Looking for a V spray injector
I'm looking for a V spray injector to be used in a dual intake valve motor. Need it rated 364cc/min at 3 bar with a total height arround 2 inches. This is for an alcohol conversion 600 cc motor. Whoever converted it used a pencil spray style injector in their conversion. I believe it would work better with a V spray to spray toward both valves. This is a ported injection system. Am I looking at this correctly? Open to any suggestions. Thanks in advance.
RE: Looking for a V spray injector
Magneti Marelli also make twin spray "Pico" style injectors that have stainless steel bodies.
