Off the shelf 20 hp gear pump/driver
Can anyone give me an idea where one would find pump/driver such as the above?
RE: Off the shelf 20 hp gear pump/driver
Sorry, I guess I was expecting you to read my mind.  We're pumping water, need at least 40 gpm at 150 psig.
Your pump only require about 5 HP.  I have not seen off the self pumps in the range you are looking for, here is one that is almost off the shelf.
http://www.rotor-tech.com/electric.htm
