Ansient 2D Documentation
I have a lot of 2D draws done with a program called MAZURKA, now we've lost the original CD cause we made it long time ago and then we started to use Autocad and now Solidworks, the problem is that we need some information from this draws, anyone knows how could I transform MAZURKA files to DWG or DXF? then we will be able to introduce it to PDM system.
I've found a lot of sites in the web and I don't find information about this program, maybe it was bought for PTC?
Please help me.
Thank you.
Quico
Please help me.
Thank you.
Quico
RE: Ansient 2D Documentation
I'm going coming up with Polka dancing when I look it up on Yahoo! Search. It may be easier, more efficient, better for posterity, and cleaner just to recreate what you need natively in SolidWorks. Do you have print out of the drawings to work from?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
Can you scan them and save as PDF and use in PDM system?
I would be heading over to the Usenet group alt.machines.cnc and asking if any of the members over there use the Mazurka program. They may be kind enough to translate the programs for you.
ht
Anna Wood
SW07 SP2.1, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
WD Raptors, 1 Gb network connection
http://designsmarter.typepad.com/solidmuse
Thank you Anna, but there are a lot of file to translate and it could be too much hours, if anyone know how to translate and can tell you...
Thank you for your help!!! You are great!
Quico
i.e. What extensions do they have?
http://64
Do you have any other information? Original vendor, support company, etc?
Thank you.
Quico
"You will also be a competent user of Mechanical CAD tools (Mazurka and Pro-Engineer) "
http
The reason I bring this up is that it seems like it wasn't a very popular program and you will be hard pressed to find a file converter without the actual program.
http://filext.com did not list those file extensions for a cad/cnc program either. Sorry, but you may be S.O.L.
SW07 SP2.0
Flores
Also http://ce.vtt.fi/iaiIFCprojects/
I've no idea if they are even close to being what you need, but maybe worth a look.
http://www.infographics.co.uk
With regard to file extensions, if I remember correctly, IFC was the earlier file extension and I've a funny feeling it was linked to the CAM-X format so they could interface. MDR was the later Mazurka format.
