nVidia Video Card
nVidia Video Card
nVidia Video Card
Hello All
 I would like to get a nVidia Video Card for my home computer.  I have a Gateway AMD 3800+ Dual Core, 3Gb of RAM and Windows XP Pro.  I was looking at the Quadro FX 1500 and Quadro FX 3450.  Any suggestions about a video card.  Thanks.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
RE: nVidia Video Card
I have the FX1400 on my work computer and it's a great mid-range MCAD V-Card.  Two things that are important to a MCAD machine RAM and V-Card.....go big!
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
Get the best Quadro FX card that your budget will afford.
cheers
I really must disagree, instead of buying a FX3450/3500 you should spend your money on a FX1500 and a CPU upgrade.
The FX3450/3500 cards need a faster cpu to reach their full potential (I came to this conclusion after benchmarking my FX1400 and FX3500 on several systems).
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Only Quadro card not to get is the FX NVS - its not a CAD card  and its the only FX card that is not supported.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Stefan - I would like to see the results of your benchmarking.  And how much faster than a AMD 3800 dual core?
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
I tend to agree with Stefan.  I went from one system to another--the first had an FX-500, the current has an FX-1400 (or 1440 "Express"--whatever).
I saw strange artifacts and things that wouldn't refresh right away on my old system, thinking I was running out of card power with the huge assemblies and complex geometry I was doing.  That stuff (for the most part) did NOT go away with the upgraded system and card.  It appears a certain amount of what I didn't like is actually endemic to SolidWorks.
Hence, I'd go for more processor power (and did) in a system on my next purchase as well.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
I'll see if I can find more, for starters, here are some cinebench results:
CPU / MHz | Video card | Rendering 1 core | Rendering multiple cores | Shading CINEMA 4D | Shading software OpenGL | Shading hardware OpenGL
 1. C2D 3370          | FX3500OC     | 584 | 1097 | 677 | 2398 | 7971
 2. C2D 3240          | FX3500OC     | 562 | 1053 | 653 | 2310 | 7784
 3. C2D 3440          | FX1400OC     | 594 | 1126 | 697 | 2459 | 7654
 4. C2D 3440          | FX1400OC     | 603 | 1128 | 696 | 2453 | 7621
 5. C2D 2920          | FX3500         | 507 |  956 | 590 | 2082 | 6916
 6. C2D 3370          | FX3500         | 582 | 1098 | 680 | 2205 | 5179
 7. C2D 3440          | FX1400         | 603 | 1121 | 696 | 2221 | 4766
 8. Opty 175 2640   | FX3500OC     | 444 |  831 | 435 | 1799 | 4726
 9. Opty 175 2637   | FX3500          | 442 |  831 | 436 | 1798 | 4688
10. Opty 175 2637  | FX3500          | 442 |  825 | 436 | 1790 | 4669
11. C2D 3340         | FX3500          | 603 | 1120 | 695 | 2208 | 4572
12. HP 2085ea 1833| Geforce 7200 | 273 | 492 | 321 | 1261 | 1972
Stefan Hamminga
EngIT Solutions
Thanks Stefan.  Then this opens up a new can of worms when building a MCAD system and should SWx recommend systems?  The reason why I ask is our IT guys, although good at what they do, have not the first clue what's important when it comes to building a MCAD system.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
Thanks for all the comments from everyone.  I think I will go with nVidia Quad FX 1500.  I can one for $625 CDN. from Tigerdirect.  Again thanks for the help.
Cheers,
Ralph Wright, CSWP
P4, 2.53Ghz
1.5 Gb RAM
Windows 2000 Pro
