Gluing clear acrylic to ABS
Anyone have any experience with any of the available adhesives for bonding acrylic (PMMA) to ABS? I know Dymax and some others make adhesives.
This is for a low cost consumer product. Both parts are in a a cosmetically sensitive area (visible to user of end product) so I don't want to be able to see adhesive residue....especially on the acrylic.
apdesign.
apdesign.
RE: Gluing clear acrylic to ABS
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
I have some ABS motorcycle fairings that require some small crack repair, and need to know if I have to teach myself plastic welding, or if some basic adhesive will provide a bond with some flexibility.
Sorry to threadjack here.
http://
http:/
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks. Does ultrasonic welding abrade a really polished visible surface like clear acrylic? I'm trying to bond a clear acrylic window to a base made of ABS (imagine a square box that youre trying to bond a clear window to the open side os.. The base is about 1.5 inches deep. Im not sure where the Ultrasonic horn would have to go in order to bond from that far away or if the result would be ugly after the ultrasonic bonding.
Ultrasonic horns cost ~$10-$20K, right?
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
Triplez:
I repaired my motorcycle fairing (broken off fixing lug) about 4 years ago with Loctite 406 - still ok.
Fairing is ABS.
Cheers
Harry
