dwg as sheet format
dwg as sheet format
dwg as sheet format
I'm trying to convert a dwg title block to a solidworks sheet format.  In the new template I either end up with the format as a drawing view or it's not visible at all.  There seems to be a number a ways to do this.  Anyone find a simple solution?
Thanks All.
RE: dwg as sheet format
When you get the title block set-up the way that you want it goto: File; Save Sheet Format. If you want to save it so it shows up in the New Solidworks file dialog then you have to save it to the templates folder within the solidworks folder. If you want to just have it as a sheet style option then you have to save it in the data folder within the solidworks folder.
Copy and paste it on the other side - Please do a search because I just told someone how to do this last month.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Templates vs Sheet Formats  thread559-87964
Also take a look at Help > SolidWorks Tutorials > Customizing SolidWorks.
cheers
