Your Thought On "Planners"
Any recommendations on “planners”, both hard copy and electronic?
Here’s my history, thoughts, and desires:
1. I’ve used in the past DayTimers, both small and medium size. While I saw many advantages, I found replacing and storing a large volume of paper every month a pain.
2. I often use “steno-pads”, the 6”x9” spiral notebooks, which I simple replace the “old” with a “new” nearly every month. I have years worth of these, which I find helpful when I occasionally need to look at my original notes from a meeting in February 2001. However, it is cumbersome to track schedules with these.
3. I use three distinct computer systems, each with their own OUTLOOK calendars (different offices, projects, customers). I’ve not found an easy way to “synchronize” these, even though I work off a laptop. Hence, when I accept a meeting or appoint on one system, I “cc” my other systems in my acceptance. I then go to the other systems and manually input the appointment, so my OUTLOOK calendars are hopefully up-to-date (why I have three systems is another story, I support multiple customers/projects, and they each want “their” system used).
What I'm seeking is a computer-hardcopy hybrid that can:
- import/export info to/from my various OUTLOOK accounts in an easy manner (automatic would be great, but I suspect that’s pure fantasy),
- easily print out “to do” lists and monthly calendars,
- mesh with a hard-copy version so I take my notes with me, and take notes wherever I happen to be.
Any suggestions or thoughts?
RE: Your Thought On "Planners"
A few key points:
1. A good one will be able to sync up with 3 different computers with no problem. Your statement that "automatic would be great, but pure fantasy" is happily incorrect. There are systems that sync as soon as you plug it in, or at worst, at the touch of one button on the PDA receptacle.
2. You should buy a full size, foldable keyboard specifically for your model. This will allow you to type in notes. From your post, I don't believe the handwriting recognition software could keep up with the volume of notes you're taking, but you could sketch on screen if required.
3. A high end PDA will be able to run Excel, Word, and Powerpoint, giving you flexibility on moving documents from machine to machine and having access to them in meetings. The Powerpoint feature will allow you to do presentations from your PDA with the right connection hardware to go to the projector.
4. There are a few pretty powerful PDA's that are also phones. This allows you to carry just one machine on your belt (this was my recent choice after carrying a phone and a PDA separately for years).
It will require a good bit of research for you to find the model that fits your lifestyle. The three most popular types are the Palm brand, Blackberry, and the many that run Microsoft Windows for PDA's. I'd sit down with a trusted IT type and go over what you're looking for. The very high-end models go for $700 or so, but once you get used to their capabilities, they are an incredible tool for a busy person and are well worth the cost.
I won't mention the make and model of mine because I don't want to sway your decision one way or the other. However, once you get into the search, post how its going, and myself and others can help out.
I use an Access database for my to do items not planned at a fixed date/time but they can have deadlines. There are usually 30-50 in parallel, so I need something electronic in order not to have too many trees cut. Each week and each day I "download" (heh heh) to do items into my agenda.
I guess I'm old-fashioned (too early!) but I don't want to spend too much time on the activity of scheduling my time.
Tobalcane
"If you avoid failure, you also avoid success."
However I do a lot of my tracking with pen and paper and then enter the data at the end of the day into Outlook on my PC. The data entry functionality is simply not there yet, in large part due to the small size of the device.
As for power my PDA charges from any USB port and I have a small battery that outputs power through a USB port and another device that takes AA size batteries and powers a USB port for recharging.(Also have the adaptors for both cell phones so I don’t run out of power on these either.) I can fly half way around the world listening to music, playing games and reading all with a device that fits in a shirt pocket. (Both extra batteries are pocket size as well, just not all in the same pocket at the same time.) If I run out then I can but batteries anywhere.
My PDA synchronizes through wire or my usual method is Bluetooth. This is not set up to happen automatically as every time I came within 10 m of my PC the synchronization program would restart. ( I can also surf the net using WiFi). This in a less than $400 item
I think that any method will work, PDA, PC, pen and paper as long as you use it faithfully. If you are not tracking everything on pen and paper (as I did for years) then going to a PDA based system will not make you organized..
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
I have a bound notebook that I use as a "day planner" and PDA. I write all my stuff in there.
I use my cell phone for meetings/reminders. It beeps to remind me that I am late to wherever I need to be.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
Just a thought.....
Prior to my current phone, I had a Treo 600 and loved it. While I didn't have internet enabled, syncing was easy with the docking station.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
I don't have a Treo, but I've sure thought about getting one. I like the grafitti handwriting input, so that's the thing about the Treo (and all the WinCE ones I've seen)that I don't like. Do some real shopping though, like at a big home electronics store. Also do some reading at
http://www.pdastreet.com/index.html
and other places.
Using it with MS Outlook will give your data the most security, as in synchronization, cross-platform utilization, data portbility etc.
One last word of advise; Buy a new one and migrate before your current one dies, or buy 2 and synchronise them with your own computer and Outlook frequently.
Please let us all know how this works out for you! and don't forget FAQ731-376
But, the PRIMARY need is schedule and calendar functions; not reading email, not taking notes.
Hints are always welcomed, but I know I need to conduct my own research.
Thank again for the hints.
He uses a Razr now.
I have a older model Handspring PDA. My work is going to give me a Blackberry.
Chris
AutoCAD 06
I've done this for years now. I review this pad of paper about 20-50 times/day (it only takes a few seconds). Sometimes the meetings make it into outlook, and sometimes the phone numbers make it into my contact list. But for the most part....it all burns it into memory.
This system seems to work great for me so far. The only draw back is that my boss can't always "see" my schedule in outlook ;)
I have the posh version of 'an 8.5 x 11 pad of company letterhead 1/4" inch scale graph paper'. My version has the words '2007 Diary' written on it and allows me to section my day into hourly segments that I find very handy.
Electronic gizmos, I'm told by various techno-junkies, can do this sort of thing as well. How impressive is that.
On a little side note. I have an electronic device that I use for phone calls as well. It can do all sorts of other interesting things, but to be honest those things generally bore me to death. But the phone calling stuff is just fine.
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
I figure I am already geeky-a-plenty. I'd rather not look like any more of a nerd than I already am. I have a hard enough time remembering to remove the collection of pens and crumbled yellow stickies out of my shirt pocket before roaming around in public.
Watching an engineer peck away at a PDA in the airport is like watching a make-up artist dip and dap away at a compact. I always assume the guy with the PDA must have had a gameboy when growing up.
I'm really not trying to get away from the the thread subject...I just believe that "planners" are simply a distraction to "doing work". I'd bet more on the engineer with the pen, paper, and scale in his hand anytime over the engnineer holding the gadget.
In my present situation, my PDA has been invaluable for another reason. Nobody here pays much attention to e-mails, it's kind of a status thing. The idea is that everybody wants to look like they have so many e-mail communications that they simply don't have time to track them all. So, if I actually need something from somebody, I have to track them down and get a verbal "face-to-face" commitment from them.
Now, here is where the PDA comes in.
Verbal commitments can be "plausibly denied" because, everybody talks to so many people and goes to so many meetings that, without followup, they can't possibly be expected to recall a 5-minute conversation they had two days ago. So, whenever I get a verbal commitment, I log it to my PDA with an alarm set to go off the next day - preferably near the end of a meeting I might be attending with them. Then, the alarm will typically go off in front of witnesses and I'll casually glance at it and say, "oh {whoever}, remember that {whatever} we were discussing yesterday?, when can I expect that?".
That has worked so well here that, these days, people are starting to get back to me *before* my alarm goes off.
Great Spirits have always encountered violent opposition from mediocre minds
-- Albert Einstein
But all the info you can store on these things is amazing! Plus phone. Plus Outlook. Plus Excel & Word & (so-so) PDF reading, Camera, Video, Dictionary, Avantgo (so you get the NY Times, Wired, Sci-Fi channel, Mapquest directions, etc.), personal diary, storing password-protected personal info (who remembers their kid's bank account numbers, eh?), quick voice memos, a great travel alarm...and so on.
Plus, most important of all...the Magic 8-Ball!
And I don't even use the Internet-enabled functions, or e-mail!
Just say hello to your inner geek. Give him a Twinkie & a bottle of Jolt Cola.
One of my Mantras is "The Tool should fit my style, I should not be forced to fit the Tools' style". I find this especially true of PDA's and laptops.
This means that I have tried PDA phones, plain PDA, day timer, yellow pads, sticky notes, and sometimes all of these at once.
So, finally (don't laugh :P) I decided to try a DIY planner. I made the pages I wanted in a DTP program and print them out as I need them. They fit on 5"x8" note cards and go in a small 3 ring binder. I am still working on the shuffling of appts./to do lists/etc. but so far I am pretty pleased with the system. I like the flexibility of the system, and I find paper and pencil still more enjoyable and intuitive than digital. I always found PDAs and computers have an "out of sight out of mind" factor that did not lend itself to my style.
If you are curious there is an interesting web site developed by a DIY group here:
http://www.diyplanner.com/
