proe Wildfire 3.0 and windows vista
RE: proe Wildfire 3.0 and windows vista
Ben Loosli
Sr IS Technologist
L-3 Communications
The laptop has no access to our network here at work, so I couldnt try to use a license from our license server.
I do believe that Micros-oft might have put some things in like the Run in Compatibility mode for Win 95/98 or 2000 like XP can do.
If you happen to like Vista you could also partition your drive and have it dual boot so you can choose XP to run Pro/E or Vista if you don't need to use Pro/E.
Michael
http://www
in regards to getting the license working properly.
However, even with having Pro/E working, it runs painfully slow in Vista.
Ben Loosli
Sr IS Technologist
L-3 Communications
Nvidia beta drivers (feb. 15th)
htt
