Differential Pressure Across a Jet Ejector ()
I want to simulate the effect of mixing two gas streams of different pressures via a jet ejector (eductor).  The aim is to use the high pressure gas to induce higher flow to the stream of lower pressure.  I am looking for pressure correlations between the two entering pressures and the eductor discharge pressure.  I found a graph in Perry’s but there is no way of getting an equation out of the graphs, so that I can simulate the case and quantify the effect of putting an eductor in my system.  Any ideas where I can find such correlation?
RE: Differential Pressure Across a Jet Ejector ()
Go to www.graham-mfg.com and register for their free software called Vacworks II.
It has a thermocompressor program in it and it can guide you to what you want to do.
It also has a good section on gas properties.
rmw
I had a look at the site, interesting reports.  I requested the software but received no response. Thanks for the suggestion though.
Next suggestion is to contact a Graham rep for your area.  They have them as give-aways.
rmw
