Motor Specifications
Can someone please tell me what specifications should I seach for and where in order to find a reletively small unidirectional motor with torque of 3 N.m , 3000rpm....thank you
Sara.
Sara.
RE: Motor Specifications
AC or DC?
We use Pittman motors on a few of our products. http://www.pennmotion.com/
Reletively small?
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
I also have another question; I am looking for a Solonoid valve antidrip system (the whole system) do you know where I can find them? Also I am not sure if the valve should be one way or two way valves in order not to get leakage from the valves (should I use two way valves to avoid leakage from the pipes connected to the valves)...Thank you
Bests,
Sara
