Portable Hardness Testers
We'd like to test the hardness of a generator shaft after a shrink fit assembly. The generator is about 200kg and is difficult to test on a regular Rockwell tester. I'm considering renting a portable hardness tester but have no experience with them. Are they reliable? How accurate they are? Any specific types or brands you can recommend? Thanks.
RE: Portable Hardness Testers
This service is largely provided by the NDT agencies in India,overseas too it might be the same.
Equotip is one such brand .
http://www.proceqasia.com/en/index.php
Krautkramer/GEIT produce very high quality equipment.
Nigel Armstrong
Karachaganak Petroleum
Kazakhstan
I use a portable kit from : http://www.mcmaster.com/
It is part number 1342T13 and currently sells for just under 700 bucks. Its advertised accuracy is +/- 1.5 HRC
It's accuracy is highly dependant on your eyesight, but I would say I can determine within 2 points fairly easily.
I have found it to come up with readings very close to my regular machine.
Now I have to sell the idea to my manager. Thanks.
Rao Yallapragada
http://www.hardnesstesters.com/default.htm
Browse their site for hardnesss testing info & ISO qualified testing.
King Tester Corp.
http://www.kingtester.com/
True AMES Rockwell portable hardness testers are manufactured by ElectroArc
sales@electroarc.com
http://www.welding-advisers.com/
We have also experienced people using the machine on an alloy which does not have a hardness conversion scale available, and so getting some very wrong hardness values and rejecting material as a result of this.
You should be OK if you follow the instructions, and are working with carbon and low-alloy steels.
