Changing Table Border Properties Causes Display Problems
Using AutoCAD 2006;
I created a table with the borderlines visible. I then modified the table by setting the borderlines to invisible. The procedure worked well. After editing existing text, the entire table disappeared.
Any suggestions how to make the table re-appear?
Any response will be greatly appreciated!
RE: Changing Table Border Properties Causes Display Problems
