Off-centered agitator shaft design
We need to determine the size of a off-centered agitator shaft with no bottom steady bearing. We are concerned about the fatigue issue because of an additional bending force due to the off-center. Can anyone help on how we can estimate that force without CFD or how much bigger the shaft probably needs to be compared to center-mounted one if it off set by 20% of the tank ID. Thank you,
RE: Off-centered agitator shaft design
Good luck,
Latexman
