External Design Pressure Error
I'm getting the following deficience error on my top head of a vertical tower:
* External design pressure varies across this chamber.
Any thoughts as to why?
RE: External Design Pressure Error
You can inspect the specified design pressure for all components by using the Global Change dialog (Action menu). Or you can simply use the Global Change function to change all components to the same design pressures without further ado.
Tom Barsh
Codeware Technical Support
I figured that was it, even did that before posting, using the global change to update my external pressure but still got the same error. I just did it again and the error has gone away.
Lesson learned: never under estimate the power of a re-boot.
Thanks again.
