PROE20001 ASSEMBLY
PROE20001 ASSEMBLY
PROE20001 ASSEMBLY
I have proe2001 student version
When i want to open a assembly the text: this functionality requires one of pro/eng pro/infosolodin pro/cabling.
What is this.
Sorry for the bad english i am from Begium and a starter.
RE: PROE20001 ASSEMBLY
Hi, I think you are short of the licence for either module (pro/infosolodin pro/cabling) or your student version is not a complete version for all the modules that required to open the assembly file.
Pro E user
When you open ProE, select Help/ Customer Info and read the available modules that you have. If Pro/Cabling is missing, then you cannot open those parts, but your top-level assembly will just fail, so suppress those parts.
Steve
http://www.3dlogix.xom
