another horizontal cylinder question
Mr. Smart,
   I have an interesting situation.  I am working in a subdivision with very little elevation change.  The outfall ditch that i am draining to is approximately 4 feet below the elevation of the adjacent lots.  I want to model portions of the storm sewer system as horizontal clyinders.  I want to install flap valves at the outfall locations (multiple storage facilities).  How can I model this?
Thanks in advance.
RE: another horizontal cylinder question
You can model the pipe storage as a "pond", as long as there is a specific outlet control, such as a weir or orifice, in order to create a level pool across all the included storage volumes.
The pipe storage can be calculated using the "horizontal cylinder" option (with an optional slope.)  For details see www.hydrocad.net/pondstore.htm
If you have tailwater effects at the outfall, this can be handled with the dynamic storage-indication method.  The flap values are easy, since reverse flows are automatically blocked unless you setup reverse outlets (which aren't required in this case.)
