Cutting Drawn Over Mandrel Steel Tubing
Hello All,
I am new here. I have read a number of helpful posts all of you have posted. Very informative! I really hope you can help me with my question here:
I want to purchase a drawn over mandrel welded steel tube with these dimensions:
3.25" OD
2.75 ID
My question is:
If I were to cut this tube in half down its length, how much spring-back should I expect?
Any help would be greatly appreciated.
-Bluethunder
3.25" OD
2.75 ID
My question is:
-Bluethunder
RE: Cutting Drawn Over Mandrel Steel Tubing
http://www.welding-advisers.com/
Could you forge/cast the final shape that you are looking for. The issue of spring back then disappears.
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
Thanks for your responses.
Prohammy,
I need to get this material as soon as possible for my project since it is readily available. As a result, casting, unfortunately, is not an option.
Goahead,
I think I may be able to ask the supplier to stress relieve the material for me. Thanks!
-Bluethunder
Can you weld the "whole" pipe in place first and then cut it in half as desired.
Press brake or something? How many pieces?
Mike
I would suggest the press brake route also.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Press brake ideas are very good! However, it would be less expensive for my department to buy the tube and slice it lengthwise in half....... the suppliers I contact did not have any data as far as how much the tube would open due to residual hoop stresses. I think, from gut feel, that it will not be much where it would affect my intended application negatively.
-BT
